Control arm pinch bolt - with an extra serving of stupidity
Old Feb 17, 2010 | 03:57 PM
FASTER's Avatar
Tech Slut
if you cut it into sections, try a tungston carbite drill bit. and smack the **** outta it with a small sledge and a punch inbetween drill sessions. it shouldnt be too hard. gl
Old Feb 17, 2010 | 06:27 PM
dragonrage's Avatar
Is there any sort of press that I could fashion and use if need be? I'm gonna try the hammering method again tomorrow when the parts come in. Hopefully the SiliKroil helps. Think of the difference from WD40 up to PB Blaster. That difference again is Kroil. Unfortunately, carbide drill bits don't seem to be available at HD/Lowes/Sears except for masonry bits :/
Old Feb 17, 2010 | 08:49 PM
hiwords's Avatar
you could try using a small bolt and using a c-clamp to try and push it out. i doubt it'll work but i guess it's worth a shot lol. try one of those drill bits in the link below. you can put your zip code in at the top right to filter out what's not at your local store
http://www.lowes.com/pl_High+Speed+S...Ntk=i_products
Old Feb 17, 2010 | 08:53 PM
Dallas09's Avatar
Unless you came up with a mad, powerful press, usually pounding works better at least for all of my front suspension problems. It would be hard to make a press that would fit in that space, and on the small surfaces, but yet large enough so you could crank on it.
Ralf5k
Aug 13, 2015 11:10 PM
hartsoe1
Dec 7, 2012 11:22 AM
vgo
Aug 1, 2012 10:04 PM
raudi28
Aug 24, 2011 04:11 PM
legendpilot
Mar 12, 2009 08:57 AM
