Coolant Issue
Old Jun 23, 2009 | 07:15 PM
DENIS415's Avatar
Question Coolant Issue
I tried searching already but it wasn't helpful. I vag'd my car today because i had a cel, and found that my brand new maf is not working for some reason. I have also noticed that the car doesn't cool down after i drive it, and the engine bay is steaming hot. I popped the coolant reservoir open and noticed that the fluid is milky. Now i know the G12 fluid is pink when first poured in, but should it get milky? Maybe something here could be my cooling down problem, a bad pump? The coolant sensor works fine and displays correctly on the dash, indicating that there is no problem. Only when i park the car, i can smell what seems to be the coolant and see that the engine is not cooling down. Thanks for any help in advance!
Old Jun 23, 2009 | 08:07 PM
bkraska's Avatar
How is the engine oil level? Milky coolant could be from oil mixing in with it. It is possible the oil cooler right above the oil filter is bad. I am not sure what you mean when you say "the engine is not cooling down after I park it" If the engine is off, how can it not cool down?
Old Jun 23, 2009 | 08:48 PM
DENIS415's Avatar
oil level looks fine, the oil could be mixing but im not sure on that. Any way to check? I was trying to explain that the engine is way hotter than usual, and i can smell coolant.
Old Jun 23, 2009 | 10:00 PM
hiwords's Avatar
what color is the coolant now? i don't think oil mixed with coolant could turn into a lighter color. are the temp gauge reading ok? you can flush out the coolant and fill the system with just water and see what happens.
Old Jun 24, 2009 | 12:57 AM
ghost6303's Avatar
have a compression and leakdown test done to make sure your head gasket isnt on the way out. youve been around here for 3 years you should know to provide some information about your car when you post by now. if its a 1.8t check the oil cooler.
Old Jun 24, 2009 | 02:09 AM
DENIS415's Avatar
Yeah i know, i was in a hurry when i wrote the post. 2001tqm around 90K miles. I will check the oil cooler tommorow, and see in what condition it is, as well as the compression tests. I'm due for a tb replacement next week, so this is a good time to get everything sorted out.
Sean1234
Nov 18, 2013 07:49 PM
StormUnite
Oct 4, 2010 06:11 PM
j_ripper19
Mar 30, 2009 01:09 PM
Remman
Mar 15, 2008 09:59 AM
silveraudib6
Mar 12, 2008 10:59 AM
