Coolant Leak
Old Jul 23, 2013 | 07:12 PM
MyFreeAudi's Avatar
Question Coolant Leak
I have a coolant leak at the front of the oil pan where the front engine mount bracket is. It seems to be coming from between the two.
Is this the dreaded water pump? Do I wish I had done the water pump when I did the timing belt two years ago? I have a 2001 1.8t with 160,000 miles and the water pump is original.
Could it be anything else? I have looked all I can without putting it in "service position." If I get in there, is there a "weep hole" like on other cars? Any other advice?
Thanks,
John
Old Aug 6, 2013 | 06:08 PM
MyFreeAudi's Avatar
Default Result
Yes, it was the water pump. There are streaks of coolant in the timing belt region.
It's a good thing I enjoy working on cars!
Old Aug 6, 2013 | 08:58 PM
Nebuchadnezzar's Avatar
Ouch. I feel for you not doing the water pump when you did the timing belt. You were about 14 bolts away from getting the water pump off when the timing belt was off. You'll be wishing you installed a new pump once you get started on it!
Good luck!
EDIT: ...About 14 bolts on a 2.7T, that is. A little different on your engine.
Old Aug 7, 2013 | 07:09 AM
MyFreeAudi's Avatar
Good luck!
It's THREE bolts and maybe $40 on the 1.8t! My "thinking" if you can call it that was that I did not want to mess around with draining the coolant!! The timing belt was frustrating the first time, as noted in my post elsewhere. Oh, well, live and learn.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
