coolant leak
Old Jun 23, 2014 | 12:56 AM
43bullet's Avatar
Default coolant leak
Recently sprung a coolant leak. It appears that on the bottom of the expansion tank there is a valve/vent. coolant is leaking from this, and it will continually leak out. I can find no other leaks, and I have pressure tested the system. and when I pressurize, this is were the system is leaking.
so, my question is, is the hole on the bottom of the expansion tank a valve, or is there supposed to be a cap and mine is missing? looking on audiwholesaleparts, the parts diagram only list the expansion tank without going into detail about the function of the valve onthe bottom of the tank.
any help really appreciated.
thanks - dan
Old Jun 23, 2014 | 09:43 AM
mtroxel's Avatar
Neither. That's where the coolant bleeds out when the cap thinks there's too much pressure. Your cap is the "valve". Buy a new cap.
Old Jun 23, 2014 | 10:27 PM
43bullet's Avatar
so if I pressure test the system, it SHOULD bleed out the bottom? thats the only place it is leaking that I see. that would be a great simple fix.
thanks
Old Jun 23, 2014 | 10:49 PM
hartsoe1's Avatar
replace the tank and cap. the tanks crack. maybe
Old Jun 23, 2014 | 10:50 PM
mtroxel's Avatar
Depends on how your tester fits in there. If you look down the mouth of that tank, you'll see where anything that escapes the inside ring is going to end up going down that drain hole. The bottom line is that the cap is the safety valve for excess pressure. If the cap lets pressure out, it's going down that drain hole.
Old Jun 23, 2014 | 10:53 PM
hartsoe1's Avatar
can we agree that there is not a bleed valve on the bottom of the tank?
Old Jun 23, 2014 | 10:54 PM
mtroxel's Avatar
They do. They also "leak" out the bottom, by design. If it's coming out the tube circled in red, it's just the overflow.
Old Jun 23, 2014 | 11:00 PM
hartsoe1's Avatar
I've only got 205,000 miles on my 1.8 so I stand corrected. cheers
Old Jun 23, 2014 | 11:02 PM
mtroxel's Avatar
I only know because on a 2.8 it leaves white coolant residue on my heater hoses and makes me think I have a leak when I don't....
Old Jun 23, 2014 | 11:06 PM
hartsoe1's Avatar
no, you have 207,000 and I have only 205,000 miles. more experience, you.
