coolant running low no leak.
Old Jun 27, 2011 | 06:35 PM
yellow_submarine's Avatar
Default coolant running low no leak.
Hi im been having this problem for the last 3 months now. my will slowly run low with no trace of leaks. happened about twice now. any ideas where i should look at? and yeah no white smoke or sweet coolant smell coming out of the exhaust. plugs are fine. i highly doubt its head gasket. could be water pump? watcha all think?
Old Jun 27, 2011 | 08:11 PM
Lornnn's Avatar
might have a leaking coolant temperature sensor
http://www.audiworld.com/tech/eng47.shtml
recently found this to be the case with my 2.8 which, compared to this DIY on what i'm guessing is a 1.8T, is a lot harder to reach
the O-ring might be shot, check under your car near the rear of the engine for drips after a good drive
even though you said no trace of leaks, either with the 1.8 or 2.8 and a flashlight you could see visible coolant crust or not and just rule it out
Old Jun 28, 2011 | 07:23 AM
CCA4's Avatar
What's the oil look like? Could be leaking into the crank case somehow, maybe head gasket, oil cooler, something along those lines. If you're looking for puddles, you probably aren't going to find any. Most of the time coolant leaks will appear as a pinkish-white crust at the site of the leak instead of actually dripping anywhere.
Old Jun 29, 2011 | 04:13 PM
dlcain's Avatar
I'm betting on the sensor housing at the back of the engine. Mine had a hairline crack and took me forever to figure out where the coolant was going. had it not been for some great threads on here, I may have never found it
Old Jun 30, 2011 | 06:36 AM
found some crusting on the firewall behind the engine. about 3 inches down from the top of the firewall.. however its not pinkish at all. it is somewhat really black or burnt crusting. could this be it? also i'll check the coolant lines and other areas that was mentioned when i get a chance on my next day off. thanks guys.
Old Jun 30, 2011 | 08:13 AM
Audisaurus's Avatar
Thats it!
http://www.audiworld.com/tech/eng54.shtml
hope you have the V6 if not then that wont help
Old Jun 30, 2011 | 08:14 AM
Audisaurus's Avatar
Old Jun 30, 2011 | 11:16 AM
jdahlen24's Avatar
You might also want to consider replacing the coolant expansion tank and cap. I was getting the same symptoms and replacing those solved the problem for me.
Old Jul 1, 2011 | 05:14 AM
1.8 has a different approach? I have a 2001 1.8 , Thanks for all the help i really appreaciate it. I'll go order the part now.
SubaruHyundaiAudi
Feb 24, 2014 10:46 PM
Cioffie
May 19, 2013 10:24 PM
RickOchet
Aug 2, 2009 07:51 PM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
