cooling loop cracked?
Old May 26, 2014 | 05:45 PM
nlinesk8s's Avatar
Default cooling loop cracked?
I'm working to get a 2000 1.8 back into operation. One of the things I noticed was that it was leaking power steering fluid. It appeared to be leaking at the joint of the cooling loop and hose.
I cut the last inch of the hose, and used a screw clamp to resecure the hose to the loop. And it still leaked. I took the hose off and felt around the cooling loop itself, and I can feel what looks like a small crack along the length of the tube in the area where the hose would clamp.
has anyone else had the cooling loop tube crack?
thanks,
Old May 26, 2014 | 06:19 PM
bshusted's Avatar
Seems like a strange place to crack. The cooling loop is simply a section of soft aluminum tubing. I've had a leak there as well. It was the clamp that had cut into the hose and caused it to leak.
Old Jun 5, 2014 | 04:12 PM
nlinesk8s's Avatar
I cranked the clamps down more and so far no leaks. I could see what looked like a fine crack on the outside, but it didn't go thru
freestyleski
Apr 5, 2008 02:57 AM
JohnnyBravoA4
May 9, 2007 03:50 PM
nickellis14
Mar 14, 2007 07:49 PM
JETSPEED333
Mar 14, 2007 07:32 PM
guyjusthere
Nov 14, 2006 11:47 PM
