could someone get back to me
Old May 19, 2009 | 01:07 AM
redline380's Avatar
Legal Moderator
Originally Posted by Midniteoyl
Well, they can work then not.. Like when there's no or restricted oil...wont be this way long before it just doesnt spin any more though.
i dont think you know exactly what a journal bearing turbo is. basically, the most important part is a shaft inside a cylinder that rides on a sheet of oil. if there is no oil, the shaft creates alot of friction with the cylinder because its spinning at ungodly rates. this friction is not a good thing. in fact, it is basically the worst thing. so if your oil lines are clogged or not giving any oil period, your turbo is ****. period.
Old May 19, 2009 | 01:09 AM
P.O.S._for_today's Avatar
how would i check that?
Old May 19, 2009 | 01:20 AM
Midniteoyl's Avatar
Okie dokie..
with a ball bearing, lack of oil will wear the '*****' and cause noise as a sign...
with a journal, or 'bushing', the clearances are enough that things will turn until the shaft heats up, expands, and seizes. Think 'shaded pole motor', ie, your common house fan...
However, POS, he is correct in that we need more info. Its really hard to do this without it.
Old May 19, 2009 | 01:23 AM
someone told me this all could be caused by the abs and brake light beibg on... and how do you check the lines to the turbo as to wether or not it is flowing properly
Old May 19, 2009 | 01:26 AM
Midniteoyl's Avatar
Journal turbo...
http://www.turbomagazine.com/tech/04...t_1/index.html
The journals:
As you can see, they are just bronze bushings. See those little holes? Those are for pressurized oil. If they are clogged, or fill with burnt oil known as 'coke', little to no oil can move through. Same with the lines to and from the turbo. Oil in this case is the 'bearing' the shaft rides on, with out it things heat up quickly and the turbo stops spinning.
Old May 19, 2009 | 01:27 AM
ok...sp how can i verify that? and moreso what are the solutions?
Old May 19, 2009 | 01:29 AM
Midniteoyl's Avatar
I dont see how the ABS light being on could do this, but with all the 'safety' crap built into the ECU who knows...Highly doubt it though.
Checking the lines is prolly gonna have to be pulling them and looking...
Old May 19, 2009 | 01:31 AM
  #18
ok...as for safety...
every once in a while after first starting the car, the lights will be off and i drive it...but the brakes dont work...and even better, random engage at 60 mph in the back right and slow me to 0.
Old May 19, 2009 | 01:41 AM
  #19
Midniteoyl's Avatar
ouch! I'd definitely take it in and get it the once over. Engine, tranny and brakes/ABS. You have a lot going on and seemingly multiple unrelated problems.
Old May 19, 2009 | 01:47 AM
  #20
yeha tell me about it.....i feel like its going to kust die...even when its piping hot it seems that the turbo works sometimes...its just so odd.
