Crank but will not start
Old Jul 17, 2010 | 01:15 PM
pwaudi's Avatar
Default Crank but will not start
I have a '96 2.8 L quattro. For the past six months I would use 91 ocatane gas, but then I chose to try the regular 87 octane (trying to save a few bucks). After about 3 weeks of the 87 octance I got a couple of CEL codes, since then I have switched back to 91 octance. These are the engine codes I got:
1. P1606 - Rough Road Spec, Engine Torque ABS-ECU Electrical Malfunction
2. P0402 - Exhaust Gas, Recirculation Flow Excessive Detected
I still drove for about a month with these errors - I figured it was a bad EGR valve.
Now the car won't start - it cranks and cranks but won't fire up. It seems like there is no spark. Is there an easy way to check if my timing belt snapped?
Any other ideas?
Thanks for the help!
Old Jul 17, 2010 | 01:29 PM
onepoint8tee's Avatar
The switch between octane levels has nothing to do with it. The EGR code could point to a problem with it or a vac leak large enough to keep your engine from starting. If the timing belt snapped you would know it because it would sound and feel totaly different when cranking. Search for the 2.8 vacuum line diagram if you need to.
cruukedeye
Feb 6, 2025 01:03 PM
Halfpint2209
Apr 22, 2019 08:42 AM
dasilvab2
Jun 1, 2014 05:25 PM
fukinavit
Aug 23, 2010 09:16 AM
jbangsund
May 13, 2010 06:36 PM
