Cruise Control
Old Aug 13, 2010 | 03:06 PM
Bertoli1.8T's Avatar
Default Cruise Control
Ive never had it therefor can't really miss it but it would be nice on long trips. Mine just doesn't work anyone else have this problem if so what could it be. When i try to turn it on there is no light or anything telling me it is engaged so that leads me to believe its some wiring issue... am I right?
Old Aug 13, 2010 | 03:14 PM
twoeightquattro's Avatar
yes, it would be amazing if i could get mine to work also
i'm having the same problem on my 2.8.
any help would be much appreciated!
Old Aug 13, 2010 | 03:39 PM
onepoint8tee's Avatar
There is actualy not a cruise light. Check your fuse, but it's probably a bad combination switch (the whole turn signal stalk.)
If you have an AEB engine, I think there is a vac line going to a diaphragm on your throtle body that controls the cruise. Check that too. If you have an ATW or AWM engine then the combi switch is very likely the problem.
http://www.ecstuning.com/Audi-B5_A4-...nation/ES2702/
Old Aug 15, 2010 | 06:27 PM
i'm guessing mine is the whole thing, because i try to set the cruise and nothing happens :/
what do the codes for the engines mean? i'm kinda new to audi's so i'm not familiar haha
Old Aug 16, 2010 | 12:17 AM
slamburgerz's Avatar
i am also having the same problem.
Old Aug 16, 2010 | 12:22 AM
Jc61990's Avatar
Old Aug 16, 2010 | 12:39 AM
Wow, thats a very good write-up. Going to try and have a look at my module soon.
Old Aug 16, 2010 | 01:37 AM
emanuelvidal's Avatar
It happend to me the first time I tried to use it, but then I read the manual and figure that you have to press tu button really fast, and try to press the accel pedal a little. Its kinda tricky but when you figure it you, gets easy.
chooch628
Sep 5, 2007 03:32 AM
JDriver2
Jul 10, 2006 11:16 PM
A4 the Quattro
Mar 16, 2006 07:07 PM
