Cruise Control just stopped working??
Old Oct 1, 2010 | 12:41 AM
russcuss36's Avatar
Default Cruise Control just stopped working??
So I am coming back from Vegas I used the CC to speed up and all of a sudden it stopped working. I have used my cruise for a couple months now with now issues. I went to check the fuse and there is not one there. Where should I check to fix this.
Old Oct 1, 2010 | 12:44 AM
Tourbo24's Avatar
Old Oct 1, 2010 | 12:59 AM
russcuss36's Avatar
I have been looking at that post before I made this thread but am I really going to have to take my steering wheel apart to change that whole unit if thats whats bad.
Old Oct 1, 2010 | 01:02 AM
Tourbo24's Avatar
i though that the module was somewhere in the glovebox compartment. not 100% sure on that
Old Oct 1, 2010 | 08:07 AM
BrianJanice's Avatar
It's under the dash through the glove box. I soldered mine and it still doesn't work. I tested the switch with my voltmeter and it works fine. I think I might need a new vacuum pump
Those are pretty much the things that can go wrong... unless one of the vacuum lines came off your actuator.
Old Oct 1, 2010 | 01:05 PM
russcuss36's Avatar
Thanks Brian and Tourbo. I am going to check that stuff later.
Old Oct 1, 2010 | 02:57 PM
russcuss36's Avatar
Where is the actuator?? If you could take a pic that would be awesome.
Old Oct 2, 2010 | 03:16 AM
russcuss36's Avatar
It started working tonight. How odd!!
Old Oct 2, 2010 | 06:58 PM
catmandu's Avatar
Must be solar flares or some *****. Same exact thing happened to me today.
Worked on the way to soccer, did not work coming home (turned it off for a while, back on, nothing). Let it sit in the garage a few hours, worked just fine heading to the grocery store and back.
Anybody else ever have this happen and had a failure we can expect?
Old Oct 4, 2010 | 02:06 AM
russcuss36's Avatar
Is your glove box packed full of stuff?? I ask because after I cleaned out my glove box it started working. Not completely clean but not packed. I say this because maybe its a heat issue.
