Damage assessment: valves bent from broken timing belt
I am thinking about buying a 2000 A4 1.8T quattro 5spd.
It is not running, shop states low compression, bent valve when timing belt broke (but initially claimed no contact evidence on piston heads, but found bent valves when putting new timing belt on).
What do I have to prepare myself for to fix the car?
- replace bent valves?
- new complete used head
- other parts that suffer?
I want to get an idea/estimate what I am getting into (and if it is worth the effort/time/risk).
It has 140k on it. I offered 1,500 without seeing the less (less, if more issues surface when inspecting, like suspension, brakes, turbo, oil/leaks, etc.).
Asking is 2,500.
wtf, that asking is way too much for a motor that doesn't run. imo even 1500 is too much. 1000 max. if you're afraid of replacing pistons, either find somebody who will do it for you or just try it out lol. you can see the pistons when the head is off
lelia
Sep 22, 2012 08:39 PM
brupm
Aug 27, 2012 12:21 AM
