Dashboard lights
Old Feb 15, 2010 | 01:39 PM
carlosmarin's Avatar
Default Dashboard lights
I have a 1997 Audi A4 1.8T
And I have these lights on at the dashboard:
Brake
Airbag
ABS
Check Engine
Turn signals dont work even as i changed the flasher relay (emergency lights do work)
also my heater does not work....
I need guidance
Thanks!!!
Old Feb 15, 2010 | 02:04 PM
Dallas09's Avatar
You need to buy a VAGCOM to have an idea really. Brake and ABS is prolly ABS module, airbag is prolly wires under the seat (but even if you fix it you need a VAGCOM). Check engine could be anything, you need a VAGCOM to find out. If you did the relay for the blinkers, I would say check fuses and wiring, otherwise check the turn signal lever at the column. So to sum it up, buy a VAGCOM to start with. If you dont know where search VAGCOM on the forums.
Old Feb 15, 2010 | 02:57 PM
chocalotstarfish's Avatar
Super Moderator
Thanks!!!
I had the same thing happen, heater, turn signals wouldn't work but the flashers did. It's a relay on the firewall. I think I have the paper work at home on which one i replaced. It took about a week to figure out which one. On my 1.8t I had to remove the lower panel and toward the upper left was a row of black relays. try and pull each one and test with a voltmeter. One of those is bad! the other stuff ABS and Check engine use a vag com.
Old Feb 15, 2010 | 10:47 PM
Andrew149's Avatar
if you get 3 beeps when starting the car its a bad abs module for sure im going to redo someones abs this friday
Old Feb 16, 2010 | 07:46 AM
Great guys!!!
I appreciate all your input....
I will purchase the Vagcom
Old Feb 18, 2010 | 12:20 PM
Chocaoatstarfish:
Thanks for the input, do you remember which one was the relay that you changed?
I appreciate the help!!
acuk2101
Jan 22, 2008 08:33 PM
audiS4jls
Jan 16, 2008 02:48 PM
beefski
May 13, 2005 04:27 AM
beefski
May 12, 2005 02:24 PM
bigladnelly
Jan 29, 2003 06:43 PM
