DDM HID Kit, anything else needed?
I couldn't find anything answering my question when I searched, sooo do I ONLY need this kit? No adapters or anything? I've got Depo 2-piece projectors.
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
Had mine in since after I started this thread. No issues really except I get a "bulb out" warning on my dash when they're on
I was under the impression the ddm slim kits didn't have the bulb out warning.
I'm about to buy a kit myself, where did you mount the ballast and did you drill a hole into the plastic cover to feed the wires out like most diy's say to do or did you do it differently?
I never had a bulb out warning in the 2 years I ran the kit. Used 55w 5000k slim kit. I mounted my ballasts inside the headlight as per a DIY I found on this site. I didn't have auto leveling lamps so they never go tin the way. i believe the stock 1 piece lamp have a spot on the under side of the housing for a ballast that you could use too.
i have the fullsize raptor kit.. 55w 5k. its BRIGHT. like really bright. people flashing me on the highway bright. honestly, if i was going to buy another set, i'd get the 35w. i've been using them about a year. they're awesome. but bright.
Do you get the bulb out warning with the full size Raptor kit? If so, I may have to order a set of the slim ones and get 35w for the low beams. I could put the 55w set in the high beam side.
