Does your b5 burn oil?
Old Sep 8, 2010 | 02:30 PM
Msnickbroderick's Avatar
Actual WIZARD
Default Does your b5 burn oil?
I'm starting to loose about a quart after 1200 miles... Thats not good right? I smell that funky hot smell when im under the hood, but no smoke or anything
Old Sep 8, 2010 | 03:07 PM
myriadshalaks's Avatar
just add oil when light comes on. it doesn't burn oil during combustion, it leaks out while lubricating the seals and is evaporated. all to the good.
Old Sep 8, 2010 | 03:09 PM
chocalotstarfish's Avatar
Super Moderator
you shouldnt be going threw that much... I have $$ saying you don't allow your turbo to cool down before shutting it off....
Old Sep 8, 2010 | 05:24 PM
Tourbo24's Avatar
i was loosing just around that much cuz i had a bad valve cover gasket. i just recently replaced it and so far so good. i also could feel the smell of burning oil in the car, but no smoke. my mom always asked me what the **** was that burning smell in my car lol
Old Sep 8, 2010 | 05:28 PM
Mike-2ptzero's Avatar
Burning oil is never a good thing.
Old Sep 8, 2010 | 09:04 PM
Old Sep 8, 2010 | 09:42 PM
SAudi's Avatar
my car burns about a quart inbetween changes but then again i use mobil 1 10w40 and my car has 200k miles. if you smell oil under the hood i can almost guarentee its the PVC hose under the intake manifold, atleast that was the surce of oil leak/smell on my dads 1.8t
Old Sep 9, 2010 | 12:48 AM
Actual WIZARD
I always let my car idle for about 3-5 minutes (gives me time to answer all the texts I got while driving) and cause it still heatsoaks after I turn it off. I looked around today, and didn't see any leaks, but to make a long story short, a section of my DV piping is clear, and that is completely black with oil... Would that mean I'm loosing it via turbo? I'll go out now, and poke around the head and see if I can spot any obvious leaks.
Old Sep 9, 2010 | 02:19 AM
oil in the DV hose is normal since oil vapor is sucked out of the crank and passes thru the turbo inlet.
Old Sep 9, 2010 | 08:08 AM
^yep.
