Door locks
Old Aug 31, 2008 | 07:56 PM
CAB509's Avatar
6th Gear
Default Door locks
So I have a kind of interesting predicament and I guess it's about time I try and fix it.
last time my car was in the shop the moment after I got it out of the shop the door lock snapped off. Now I can still drive the car (obviously) which is why I haven't done anything until now, but seeing as I go back to school in two weeks, I would like to get it fixed before I head back.
So my question:If you replace one lock, can you get it keyed to work with your old key, or do I have to either 1) carry a second key for just the driver door or 2) get all the locks and the ignition replaced for a new key.
here is a pic of the lock
and the part that broke off
And another question, if I have to replace all the locks on the car, would it be feasible to key them to a switchblade key or would I need to use a regular style key like I have now?
Thanks for the input,
Old Sep 1, 2008 | 11:38 AM
CAB509's Avatar
6th Gear
anyone? I could really use some insight before I go to the shops.
Old Sep 1, 2008 | 07:52 PM
ghost6303's Avatar
thats probably a good question for a dealer, you can get a key copied, but having the lock copied i would assume is alot harder. it seems logical that you would need to replace your keys and locks, but again im not sure, just call any dealer and they can tell you.
Old Sep 1, 2008 | 07:59 PM
onepoint8tee's Avatar
You don't have keyless entry right?
Old Sep 1, 2008 | 08:04 PM
auditech79's Avatar
Wow, i guess we have to cross that off the list of things that don't fail on audis........
As far as i know, you would have to replace all the locks in the car and get new keys. I would just get a new key cylinder in there and use your keyless entry as onepoint said. If you ever need to use the key you could still use it in the passenger's door to open the car.
Old Sep 1, 2008 | 09:31 PM
CAB509's Avatar
6th Gear
I have the vacum system and it does have a keyless system but I don't know where my remote is.
So then part two of the question, would I be able to use a switchblade key instead of the normal key
Old Sep 1, 2008 | 09:35 PM
Jc61990's Avatar
if you already have a switchblade keyfob then get on ebay and buy an uncut blade for your remote and have it cut to the new lock if you need to get a new lock, or maybe try and look at a junkyard for a totaled vw or audi and get the locks and keys from that
Old Sep 1, 2008 | 09:37 PM
CAB509's Avatar
6th Gear
I have pre-facelift which doesn't have the switchblade key. It just has a normal one. So I'm wondering what all is involved with converting a normal key to be able to use the switchblade key.
But the junkyard is a decent Idea, I'll have to look around for one.
Old Sep 1, 2008 | 09:44 PM
Jc61990's Avatar
does your key look like this?
Old Sep 1, 2008 | 10:20 PM
CAB509's Avatar
6th Gear
^^no, that is the switchblade, key, which is insanely fun to play with and I want my key to look like that. My Key looks like this
but it's cut to shape
