Drive Train buck?
Old Feb 4, 2009 | 12:49 PM
FASTER's Avatar
Tech Slut
misfiring?
Splinter_Cell's Avatar
Member
Originally Posted by FasterA4ThanUrs
misfiring?
the check engine light is not flashing, and i just had misfiring diagnosed and treated around 2 months ago. so i do know what that feels like.
would changing the oil in both the transmission/transaxle differential and the rear diff make a difference too? or could it just be residual kenetic energy being discharged through the drivetrain onto bad engine & tranny mounts?
Old Feb 4, 2009 | 12:54 PM
FASTER's Avatar
Tech Slut
maybe a dying fuel pump or clogged fuel filter?
Old Feb 5, 2009 | 02:26 AM
xqwizit's Avatar
A problem I had with a '99 4Runner that exhibited the bucking turned out to be bad spark plug wires. Maybe the same?
Old Oct 13, 2012 | 12:19 PM
Matthew-Michele Noh's Avatar
I know this is an old thread, but it most accurately describes my issues.. Any fixes? I've got a 99 A6 avant with tiptronic. Under light load, under 2k rpm, I have a knock and hesitation I can feel in the cabin that feels like it might be related to tranny issue. Happens more when the car is warmed up. I can reproduce it pretty easily by accelerating to 50 mph, coasting, then getting lightly back on the gas in either auto or tip mode. Any help appreciated.
Old Oct 13, 2012 | 12:28 PM
jonbonesjones's Avatar
Moderator
Sounds like a misfire, my chrystler van does the same thing. Will buck at 2k and after I hit. 3k it's fine. Check the plugs gap check the wires. Check the ignition system.
Old Oct 21, 2012 | 04:14 PM
Thanks for the reply. I've noticed the problem primarily when the car is warmed up. I tried to reproduce the problem a few times while it was cold and couldn't. I wonder if changing the tranny fluid to a thicker one could help.. Atf4 ? Any thoughts? It wouldn't be cheap to do it right and not just flush it.
adman89
Nov 1, 2012 09:46 AM
02quattrokev
Oct 16, 2012 07:27 PM
K1196A
Apr 28, 2008 06:54 PM
juju4uofa
Jul 22, 2005 11:31 PM
abacab
Jun 29, 2005 07:23 PM
