Drive without airbag?
Old Mar 23, 2014 | 11:13 AM
mtroxel's Avatar
Default Drive without airbag?
Rattle in my dash up in the center but toward the passenger side. Still don't have it, but have the glovebox and airbag out to get a better look. Any problem with me driving around without the airbag? I know it will make an airbag light (I have VAG-COM so no problem turning it off) and that I won't have airbags while the light is on (no one had them when I was a kid).
Am I in any danger of having the other air bags pop on me if I drive it like this?
Old Mar 23, 2014 | 01:33 PM
turbo510's Avatar
Nope, the airbags will just be disabled. Which reminds me, my '96 has had the airbag light on for a long time, due to driver-side airbag intermittent high resistance. I can hook up VAG-COM, select the airbag controller, and watch the codes change as I move or shake the steering wheel. I even used a Dremel to cut open the clock spring case so I could solder the crimped terminals to the copper ribbons, but there is still a flakey connection somewhere.
Old Mar 23, 2014 | 03:03 PM
mtroxel's Avatar
You might have to break down and buy a clock spring. It will add 10 HP ya know.....
Thanks for the response. I'm going to drive with the pass side apart till I track this thing down.
Old Mar 27, 2014 | 10:52 PM
John_E's Avatar
I suspect my 2001 Passat has a similar clockspring issue, since I get "intermittent B+" under the VCDS (formerly VAG-COM) airbag heading.
pologoped2
Jul 28, 2013 05:47 PM
Niclipse
Apr 11, 2011 05:29 AM
kbevere
Oct 14, 2010 09:36 AM
1BADS4
Feb 21, 2007 10:51 PM
sandnsnow24
Feb 15, 2006 02:26 AM
