Driver info Display/Rear wheel power question
Just purchased a 01 a4 1.8t quattro with a Triptronic tranny.
My first issue is that my driver info display in the middle of the cluster is not working, therefore i cant tell what gear im in when I go into manual mode. Is there a aftermarket gauge that i can purchase to indicate gear? Or is it a easy fix? The display just lights up yellow on the top and red at the bottom.
My other issue is that the rear trunk badge says 1.8t quatrro, but when I look at the bottom rear, I see no kind of powertrain going to the rear wheels.
Any help would be appreciated, Thanks....
I was going through classifieds and came across this. Not sure if it's worth it or not though
http://classifieds.audiworld.com/sho...ct/9499/cat/17
The LCD displays are known to go bad (common pixel problem). I have an older model so I can't speak from experience, but I would first try to replace it than find an extra solution
https://www.audiforums.com/forum/b5-...ge-out-165886/
http://forums.audiworld.com/showthread.php?t=1637467
That might help
As for the drivetrain question, the interior dashboard trim should also have a Quattro badge, for one. You should be able to see the differential in the rear if nothing else if it's AWD
That might help
I never ended up getting the repair done. They are like only 2 min drive from me too, but its really just a cosmetic fix but it is a pretty good price. Just pay attention to the RPM and speed to determine your gear.
Haha it's cool, I'm sure there are some enthusiasts in your area too
Coincidentally (again), I was doing a little more research for myself and found this posting with a video documenting someone replacing their LCD
http://forums.audiworld.com/showthread.php?t=2825828
