Driver side interior/door light
Old Oct 22, 2009 | 10:31 PM
collins's Avatar
Question Driver side interior/door light
Neither of these lights come on when i open the door. Is there a fuse or something that would be just to those lights or would this be a wiring issue somewhere? Looking for some direction before i start ripping **** apart to fix this.
Old Oct 28, 2009 | 11:18 PM
collins's Avatar
just opened up the dash and removed door panel to check and see if any wires were loose or disconnected. couldnt find anything so now im stuck as to where and check next. i also checked some fuses i thought it could be as well but they were all good to. any ideas of what to look in to now?
Old Apr 2, 2010 | 08:57 AM
SloRide's Avatar
i have the same problem with my 04 allroad. did you fix this? i think the door switch is part of the door handle.
Old Apr 2, 2010 | 10:12 AM
kayakman13's Avatar
Did you have the map light in the on position? Sometimes this does it for me. Check owners manual for fuse guide. Unlikely, but maybe burnt bulbs? Switch one with one from passenger side to check.
Old Apr 7, 2010 | 10:32 AM
SloRide's Avatar
On mine the door switch is located in the door handle. The problem is that the switch supplies the ground connection for that light. I tested mine by pulling the footwell light and grounding the negitive (green) wire. The light came on as well as the puddle lamp and overhead light. The real fix would be to get inside the door and remove or repair the switch inside the latch! ugh... lots of work. My fix was to install a $5 GMC door switch in the side fuse panel access door and wire one side to ground and the other side to the negitive of the footwell light. When the door opens the switch completes the circuit and supplies the needed ground to that light. I found this fix on AudiWorld, but for the life of me I can not find that post now to give credit to the dude who fiqured it out. Anyway, thanks dude good trouble shooting.
rstransky
Aug 3, 2012 02:50 AM
yellow_submarine
Aug 30, 2011 02:06 AM
SloRide
Apr 1, 2010 11:41 AM
skyy99_1111@yahoo.co
Dec 22, 2008 03:40 PM
Dec 16, 2008 05:37 PM
