dv relocation kit for a4??
Old Feb 12, 2008 | 03:45 AM
kraylon's Avatar
Default dv relocation kit for a4??
i was bored on my lunch break so i did a seach for dv relocation and every thing that it came back with was for the TT's does anyone make a kit for the A4 and would it have the same effect??
search i did https://www.audiforums.com/searchpro...mitbutton=+OK+
Old Feb 12, 2008 | 04:07 AM
cincyTT's Avatar
I'm make believe
Default RE: dv relocation kit for a4??
The effects will be the same. You can get a pipe with a flange welded on from ebayand then just cut the TB hose and insert the pipe inside and then clamp the TB hose back on the pipe and then run a new hose across the engine bay to the intake.
Old Feb 12, 2008 | 04:33 AM
NuYorka103185's Avatar
What would be the benefit to a DV or BOV relocate
Old Feb 12, 2008 | 05:22 AM
kraylon's Avatar
with one all the ones i find on ebay are for blow off valves i am using a forge 007 dv what i would like to find is a tee flanged pipe that look like this http://cgi.ebay.com/ebaymotors/Samco...3286.m20.l1116but i need one in metel either steel or alloy but i can't seem to find one
Old Feb 12, 2008 | 08:52 AM
patty AT forge's Avatar
Old Feb 12, 2008 | 01:27 PM
cincyTT's Avatar
I'm make believe
you want the metal one (doesnt matter what) so you can insert it in the TB hose. You cut the hose in 2 and then make 1/2 circles for the flange and then insert the pipe in the hose and clamp it down. Then route like stated above. You can get a flange for a turboxs on ebay you can use
Old Feb 12, 2008 | 06:20 PM
kraylon's Avatar
ha i finally found one they are called bov adapter pipes not 't' pipes
http://cgi.ebay.com/ebaymotors/1-3-8...spagenameZWDVW
and don't forget the blank plug
http://cgi.ebay.com/ebaymotors/ws/eB...23892&rd=1
total for both 35.00 shipped ill probaly spend another 20 on hose or misc supplies total for it all 55.00 roughly
Old Feb 12, 2008 | 06:41 PM
chaos92287's Avatar
ORIGINAL: kraylon
same difference[8D]
Old Feb 12, 2008 | 06:44 PM
kraylon's Avatar
yea i know they are the same i just thought they were called 'T' pipes like they are called in plumbing for water
vegastt
Jul 22, 2008 10:48 AM
Red_sapphire89
Jul 6, 2008 10:48 AM
MIMOSA
Apr 4, 2008 02:54 AM
Mobius97
Nov 6, 2007 11:00 AM
QuickSilver
Mar 17, 2007 07:54 AM
