e brake & Abs warning?
Was driving the other day when the e brake and abs light started flashing at me. I know it could be many things but I was thinking that it could be a common thing. Has it happened to anyone? if so? what was the problem?
Send it to me. I rebuild them for $100
is that what that means?
every time i scan my car for codes. when it gets to the ABS section, it scans fine. but my brake light comes on and abs flashes, and it says no codes found. is that normal or is mine shot too??
only vag-com software can detect abs and srs codes. If your brake and abs light is on or even just intermittent, more than likely its the abs module. VERY common thing on the b5, search the forum, you'll see. Samething happened to my car, got a used one which only lasted a few months, now the warning is back. Eventually I'll get it rebuilt by these guys http://cgi.ebay.com/ebaymotors/VW-Pa...1%7C240%3A1308
140 bucks
I've repaired them as cheap as $60 before. Don't mean to spam the forum, but I have the repair on ebay as well for $99. A lot of these places 'fix' involves running a jumper wire to a different connection point rather than actually repairing and upgrading the failed connection point (what I do). Don't know what that company does, but just be aware that there are some places out there that are rip offs. There is one that is notoriously bad somewhere in the southeast (don't remember their name). People have sent me hack jobs done by other people before that either didn't work or failed again. Just sayin...
Mine has been doing the same thing for awhile. Interestingly, when it is hot/warm outside, it does it right away, but the colder the outside temp is, the longer it takes to start flashing at me.
Cheers,
Doug
___________________
2001 A4 1.8T Quattro
Cheers,
Doug
___________________
