E05 Turbo
Old Jun 5, 2008 | 06:32 PM
MasterV's Avatar
Default E05 Turbo
Whats up with this turbo? How big is it? how much power can it hold? etc
Old Jun 6, 2008 | 05:57 PM
cincyTT's Avatar
I'm make believe
Default RE: E05 Turbo
It basically has the same compressor as a ko3s/ko4 but has a larger turbine wheel than both. The original had problems blowing shafts above 17psi since the shaft was to small for the turbine wheel. The revised B version (E05b) has a 1mm thicker shaft which helps, but no one runs it anymore since they reputation is to bad. Its actually a nicer turbo than a ko4 since you will have a longer powerband and hold more psi till redline. The other major downside is that the turbo cost $1200 new. You can get a DBB garrett turbo for that much. However, if you are only looking for 230-250whp and keep it basically stock, this wouldnt be a bad choiceor evena gt2x elim.
03a418tnate
Aug 10, 2010 08:07 PM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
