ECU Replacement
Old Feb 2, 2009 | 09:23 PM
Seventy7INa45's Avatar
Default ECU Replacement
I have an 01 AWM engine code A4 and I need a new ECM. Is there anything else besides the engine code that I need to order a replacement? part of the vin?
Also, is there any specific kind of TCM i need to my tiptronic tranny? Or can just a VW/Audi one from a B5 work?
Old Feb 2, 2009 | 09:53 PM
hiwords's Avatar
the ECU number must match the new one. the number is the largest series on the ECU. i believe it's the same thing with the TCM. however, we did put a 30v TCM in a 12v and it worked fine
Old Feb 2, 2009 | 11:54 PM
is the number you are talking about that sort of alpha numeric code on the actual ECU, like 11 digits? Also does it matter if the ECU is out of a passat 1.8t or does it have to be the audi
Old Feb 3, 2009 | 07:10 AM
akielb's Avatar
As long as the part #'s all match up it should work. You will need to recode for TIP/Manual or FWD/Quattro if you get one from a different setup. If you have a Vag-Com you can also just hook it up and grab the numbers from there when you check the controller.
mokey40
B7 Models
Nov 28, 2014 12:42 PM
mtnxtreme
Audi Q7
Dec 16, 2013 01:11 PM
matthayzon89
Jul 31, 2013 10:51 PM
hankeester
Jun 24, 2009 12:10 PM
