EGR Valve
Old Oct 30, 2008 | 06:22 PM
Schwalbe181's Avatar
Default EGR Valve
My CEL is on due to EGR valve. I dont really feel like spending the 400 to get the valve and then labor so im gonna DIY. Any body done this before or have a good explination on how ot do it. Seems pretty straight forward, but ill need new clamps and attachments right? Also anyone have a valve off a junker or something i could use for less money, or should i just buy a new valve. Thanks.
Old Nov 3, 2008 | 10:56 AM
Rockpundit's Avatar
Before you go on and do that. Make sure your EGR valve is actually kaput. It actually might just be blocked due to carbon build up. It shouldnt be too hard. Its on the farther end of the engine towards the right. Two bolts I should think.
Old Nov 3, 2008 | 11:25 AM
CCA4's Avatar
I get a CEL for EGR valve every coupla months, but when i clear it it doesn't come back for another coupla months, so i'm not too worried about it. I got quoted about the same to have mine done, so when i eventually replace it i'm gonna DIY as well. I'll do a little looking around and see if I can find you anything (cause i'll need it eventually too lol)
Old Nov 3, 2008 | 11:41 AM
alright thanks. My CEL has been on for about 3 months now, and the power is horrible and so is the acceleration. Ive also ran the codes and thats the only code coming up with. The EGR. So i need to do something to get it fixed so i can sell it. 3 Grand.Anyone interested?
Old Nov 3, 2008 | 12:14 PM
B5 owns's Avatar
I had a cel for the EGR and later I found a cracked vac line which can also explain for the power loss. So check those first, otherwise, the installation shouldn't be bad, just a hard are to work around..
Old Nov 3, 2008 | 12:42 PM
ghost6303's Avatar
what code are you exactly getting? i assume your talking about the kombi valve (SAI)? usualy this does not affect your power, it just pumps extra air into the cat so it burns your exhaust more efficiently, you may have another problem as well.
i think you can find a kombi valve and gasket for like $250 online and just do it yourself, its a pretty strait forward installation. alot of people even remove the valve entirely and block off the holes because its only necessary for emissions and to free up some room under the hood, although im not exactly sure how get rid of the CEL afterward.
Old Nov 4, 2008 | 09:10 AM
Rockpundit's Avatar
Im not sure thats exactly what it does. The EGR is responsible for rerouting the exhaust air (15% or so) back to the cylinders. This injection of exhaust air changes the temperature inside the engine, burns off uncombusted material and in the process lowers NO emissions.
Old Nov 4, 2008 | 05:59 PM
I took it too a dealer and two other audi shops and they said it was the EGR valve. I dont remember the exact code i want to say 410 or 414? But dont hold me to it. The loss of power may be due to other things. My accelerater is sticky, but when i do hammer down, it feels like its bogging down. Also my idle has become very inconsistant.
elduderino200
Jul 8, 2015 03:35 PM
Jfk63
Mar 23, 2011 11:14 AM
gabeguimaraes
May 22, 2009 04:46 PM
07titanium
B7 Models
Mar 5, 2009 08:29 PM
