EGR valve help! 12v
Old Nov 26, 2009 | 01:25 PM
aledelic42's Avatar
Default EGR valve help! 12v
How do you unbolt the egr valve?! I have a crows foot wrench but I can't get it to do anything. Do you turn the bigger nut clockwise or counterclockwise..?
Old Nov 26, 2009 | 02:23 PM
airguard350's Avatar
Tech Guru
That's what she said!!
Old Nov 26, 2009 | 05:03 PM
kriptonik's Avatar
^ LAWL!!
Sorry I'm no help. 1.8T here = choice of engine for real MEN! J/K
Old Nov 26, 2009 | 08:48 PM
aledelic42's Avatar
I expected that.
Nobody here can help?
Old Nov 27, 2009 | 12:27 PM
CCA4's Avatar
I have a CEL for this, been meaning to get to it but haven't had time. Are you gonna try to clean it or just replace it? I took the day off today, i'll go outside and start fiddling with mine and see if i can lend you any useful info.
Old Nov 27, 2009 | 03:03 PM
aledelic42's Avatar
I just want to clean it, if that doesn't fix my problems I'll try replacing it. I don't see how people get the thing off.. if you're able to, let me know
Old Nov 28, 2009 | 03:02 AM
shinto99's Avatar
I just found this on another forum:
"The EGR was fairly easy to take out. Unscrew the two screws holding it on, using a 10mm U-joint socket. Through the driver-side wheel well (wheel removed) disconnect the EGR pipe at the exhaust manifold, with a 22mm wrench. The whole thing will wiggle up and out of the car."
Hope it helps.
elduderino200
Jul 8, 2015 03:35 PM
Jfk63
Mar 23, 2011 11:14 AM
gabeguimaraes
May 22, 2009 04:46 PM
07titanium
B7 Models
Mar 5, 2009 08:29 PM
