Elec Fan Owners !!!
WHo has an elec fan in place of the poopy mechanical fan clutch? If so where di you tap? I was just gonna run a constant to a relay and just put it in a 12v switched ignition or put it on a switch. Other ideas?
Most people trigger it from the existing electric fan I think. Im not sure if you would want it always running at high vehicle speeds..
I bought a Hayden thermostatic relay controller to go with my e-fan. This has an input for switched ignition (ran this wire into the cabin through the ECU box), a full-time +12V, a ground, and a wire that I tapped into the AC compressor clutch (so the E-fan will turn on whenever the AC is on). This unit also has a temperature probe which is meant to go between fins on the radiator, so that whenever the radiator hits a certain temperature, the fan will turn on. And that temperature setting is adjustable :)
The fan comes on after maybe 20sec. of idling at stoplights (depending on ambient temperature) and turns off shortly after pulling away from the stoplight. It works rather well! |
Originally Posted by MetalMan
(Post 1420558)
link to said control ?
If you have it linked to turn on when the ac fan does, it is just the same to wire it in series/ parallel with the a/c fan already in the bay? just to bypass all the extra wiring of another relay and a temp control for it. |
Originally Posted by jonbonesjones
(Post 1420660)
Makes sense. Thanks for the info, I knew the wiring wouldn't be too complicated, relays are pretty simple. I got a BMW fan I think will work...prototyping
