Engine interchangeable
Old Feb 10, 2018 | 12:07 PM
Khaldoun's Avatar
Default Engine interchangeable
Dear Sir, I have Audi A4 2001 5 valves 1800 cc with very good external conditions and I love this car. But as the pertol price is increasing and the mileage is decreasing, I wounder if it is possible to chane the old engine with a newer and less capacity such as 1400 or 1600. Is it possible to do that? What is the modern and less feul capacity interchangeable engine in this case.
Kind regards
Old Feb 11, 2018 | 11:51 AM
A4TurboGuy's Avatar
If you have a 1.8t with 20V, then you have the AWM (if I'm not mistaken). It's one of the best engines Audi made for the B5 (if not the best). You can get great gas mileage out of that engine (I have 2 of them).
Before you go through all of the trouble and money of (basically) downgrading your engine, I would try increasing your fuel efficiency. You can do that by completing the following tasks:
1. Change your fuel filter.
2. Run a full bottle of Seafoam through your fuel system (just pour the entire bottle into the gas tank).
3. Change your spark plugs. (use NGK BKR 7E)
4. Change your air filter. (a high flow filter will give you more air, which means higher efficiency and more power as a result). It will also last long enough to pay for itself (and then some).
5. Use full synthetic oil and a high quality oil filter (Mobile 1 makes good ones).
6. Clean your PCV system (Seafoam can do that too).
7. Check for parasitic loss (spray WD-40 (or similar) on all of your pulleys).
8. Use a bottle of Lucas Fuel Stabilizer at least once (to lube the upper cylinders).
9. Clean your Mass Air Flow Sensor. (you can easily do this while you're changing your air filter).
If you do those things, I can guarantee you will see a vast improvement in gas milage (unless you have internal combustion issues. IE bad rings, etc.).
Those are all general maintenance items that you will have to do with any engine, so you aren't really spending any unnecessary money by doing them.
G/L w/everything.
o0hmikee
Nov 10, 2014 09:59 AM
zebinheimer
Oct 26, 2006 12:06 PM
cool_kyle_3000
Sep 23, 2006 06:14 PM
19000rpm
May 22, 2006 09:15 AM
petermcA4
Mar 16, 2006 01:19 AM
