engine problems
Old Jun 5, 2012 | 10:23 AM
audiguild1's Avatar
first is there a mil light on. if not check and listen if there is a high pitch wine coming from your fuel pump. If there is no wine from the pump and no mil light try scaning the car with generic scan tool if no comunication is possable then ECM could be the problem.
If you can read ECM check turbo diverter valve for suck open valve or turbo line for tears or leaks ususally by the boot goin into the air box down by the turbo wastegate valve.
Old Jun 15, 2012 | 09:25 AM
Steinrawr's Avatar
So. Update:
I disassembled all electronics and all component on the air intake, including the thingy (dont know the english name) with the gas lever. I heated my garage, and let everything dry completely up, blew air on contacts and electrical connection-spray.
I found a whole lot of water in the air-intake, and a lot of it seemed to have moved further into the engine. Cleaned everything up, and now: Runs like nothing happened!
PHEW.
EXTRA
May 24, 2012 06:55 PM
Jake2.0T
B7 Models
Nov 7, 2011 11:57 PM
maniorta
Apr 18, 2010 12:39 PM
painted600rr
Jan 9, 2008 03:08 AM
JohnnyPG
Apr 29, 2007 12:54 PM
