Engine Sputter
Old May 2, 2008 | 05:18 PM
stync's Avatar
Default Engine Sputter
Yes, I'm a newbie (sorry).
I bought a 1999.5 Audi A4 1.8T a week ago (155K miles). A couple days ago, I was sitting at a light (in gear, idling), and I felt the engine sputter once. The next day it happened a few more times. Today it happens often (maybe a couple times per minute).
I have not checked trouble codes because the check engine light has not come on. This leads to my first questions:
Will trouble codes be available without the CEL lit?
Can the codes be read at my local auto parts store, or is the VAG reader provide different information (other than being able to clear the codes)?
What does VAG stand for?
After reading through the forums, I was planning to change the spark plugs.
Several references to coil packs were found, but the test requires a code to be listed (reference first question).
If I should be looking elsewhere for answers, I'd appreciate some guidance.
Old May 2, 2008 | 05:29 PM
chaos92287's Avatar
Default RE: Engine Sputter
ORIGINAL: stync
Will trouble codes be available without the CEL lit? yup, some dont trigger the light to come on.
Can the codes be read at my local auto parts store, or is the VAG reader provide different information (other than being able to clear the codes)? yeah any autozone can scan it for free.
What does VAG stand for? volkswagen audi group
After reading through the forums, I was planning to change the spark plugs. good place to start
Several references to coil packs were found, but the test requires a code to be listed (reference first question). yeah unless you get a misfire for a certain cylinder, it wouldn't be the coil
start with the plugs, thats most likely it. while your at autozone pickin up the plugs have them scan the car to see if there are any codes stored in the ecu, then report back
Old May 2, 2008 | 08:49 PM
stync's Avatar
AutoZone connected a scanner which said no codes available.
I changed the spark plugs. The old ones looked OK (definitely not new), and the new ones didn't change the symptom.
The gaskets under the coil packs are dried up and aren't keeping much dirt out, and the end the goes over the spark plug was pretty dusty, but otherwise, they seem OK (can't really tell except that the car runs without CEL lit).
Thanks for the advice so far. Other suggestions?
Old May 2, 2008 | 09:41 PM
auditech79's Avatar
Try cleaning the MAF sensor, replace the air filter, and change the fuel filter if your over 100k.
Old May 2, 2008 | 09:57 PM
chaos92287's Avatar
what he said. and while your doing that, you might as well seafoam it too
Old May 11, 2008 | 01:18 AM
stync's Avatar
Mixed results...
I cleaned the Mass Air Flow (MAF) sensor and changed the air cleaner (shortly after the suggestion), and I added a can of Sea Foam toe 1/2 tank of gas. No change, and the problem has continued to get worse. Today, I finally got around to changing the fuel filter. No change in symptoms. After a long drive this evening, the check engine light (CEL) finally came on! (YEA!) I'll have it scanned tomorrow and let you know what it is.
Old May 11, 2008 | 09:45 PM
stync's Avatar
Error code says cylinder 2 misfire. I'm going to change the coils tomorrow and see how that works.
Old May 15, 2008 | 12:54 AM
stync's Avatar
Turned out to be the coil for cylinder #2. I would have suspected the coil before all this, except that I expected the check engine light to come on if the coil was bad. Lesson learned. And, I got some likely-needed maintenance out of the way.
Thanks for the help, guys!
Carl
anpm
Mar 11, 2014 12:27 PM
OneBlackAudi
Oct 3, 2008 12:14 PM
michelledw
Apr 22, 2008 09:40 PM
Audiphene
Feb 18, 2008 09:14 PM
hiwords
Jul 9, 2007 09:49 PM
