EPC & CEL are on
Old Feb 13, 2010 | 04:56 PM
msemaniuk's Avatar
Default EPC & CEL are on
2001 A4 1.8T Avant w/Tiptronic
Driving home yesterday my CEL & EPC lights both came on. I just scanned the ECU and I'm receiving the following codes.
P0322 - Ignition/Dist Engine Speed Input Circuit No Signal
P0321 - Ignition/Dist Engine Speed Input CKT Range/Perf
Based on what I've found with various search engines, I believe that my speed sensor has decided to go belly up on me. I'm hoping to get some validation that replacing the part would more than likely eliminate the problem. I'm looking at the following, though I will more than likely try to purchase it locally as I need the car roadworthy sooner rather than later.
http://www.ecstuning.com/Audi-B5_A4-...Sensor/ES9480/
If you guys think this is the right road to go down, how tough of an install is it? Where exactly is the sensor located? Thanks guys!
-Mike
Old Feb 14, 2010 | 09:36 AM
CRAZYHAWK's Avatar
http://wiki.ross-tech.com/index.php/16705/P0321/000801 agrees.
16706/P0322/000802
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
1.4 Special Notes
Possible Symptoms
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes
Engine Speed Sensor (G28) loose
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Engine Speed Sensor (G28)
Special Notes
The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
Retrieved from "http://wiki.ross-tech.com/index.php/16706/P0322/000802"
Category: Fault Codes
16705/P0321/000801 - Engine Speed Sensor (G28): Implausible Signal
Possible Symptoms
Engine shuts off
Possible Causes
Possible Solutions
Old Feb 15, 2010 | 03:08 PM
msemaniuk's Avatar
Thanks for the note. The cars in the shop getting the sensor replaced. I love working on the car myself, but I tend to be slow in getting things done. Not a good thing when you don't have a weekend & need the car to be roadworthy fast!
-Mike
