Error Code P01701
Old Oct 27, 2008 | 12:00 PM
d4stir's Avatar
Default Error Code P01701
My 2007 A4 1.8T just failed emissions... Error code P01701 Bank one Lean... hmm not sure were to start looking wither an O2 sensor or purge valve... vacum leak???
Old Oct 27, 2008 | 12:31 PM
a4r6's Avatar
Is it a constant code? Or did it come once? Do you have an exhaust?
Old Oct 27, 2008 | 01:10 PM
d4stir's Avatar
Yes... The code appeared about 1 week ago and has remained on since. I have a stock exhaust with no modifications to the exhaust or engine... should I replace the O2 sensor? how many O2 sensors does the 2001 a4 1.8t have? any other suggestions?
Old Oct 27, 2008 | 01:13 PM
McGovs2.7TB5's Avatar
'01s have 2 O2 sensors, 1 before and 1 after the cat. I would just put the code into a search on here and Audizine and see what comes up. I'm sure its been covered before.
Old Oct 27, 2008 | 02:18 PM
d4stir's Avatar
I tried a search under cope P01701 and did not have any luck...
Old Oct 27, 2008 | 05:49 PM
redline380's Avatar
Legal Moderator
i think you mean p0171 system too lean bank one. i had the same thing bout a couple weeks ago. i too thought it was my 02 sensor but i talked to a few people on here bout it and they said to change the maf. so i did and sure as hell that was the problem. definately start there.
https://www.audiforums.com/forum/sho...ning+lean+noob
Old Oct 28, 2008 | 08:57 AM
d4stir's Avatar
Redline380... thanks for that thread... I read a lot of stuff about O2 sensors creating a lean code but I am on board with a bad MAF... I will probably buy some cleaner tonight and try that until the part comes in... Thanks again for your help!
Old Oct 28, 2008 | 11:54 AM
redline380's Avatar
Legal Moderator
definately holla back with results
DCAV8R
Jan 23, 2023 06:33 AM
aaceve7
Sep 7, 2012 01:08 PM
winter001
Jan 8, 2008 07:50 PM
mikehh
Aug 25, 2006 03:35 AM
tartan rob
May 12, 2003 01:35 PM
