F**K.....Help me
Old Mar 7, 2008 | 10:37 PM
urielaudi's Avatar
Default RE: F**K.....Help me
you replace the coil pack and usualy check engine light comes off after you drive it , the check engine light should stop flashing it only flashes when its missfireing hard and the car engine shakes a bit u can tell so change the coil pack and start it check engine light stops flashing and drive it for a bit and it clears or if you have check engine light scanner then use it
Shwabmyknob's Avatar
Ok, Thanks guys for the info saves me money and time. I'll drive another car over tomorrow morn to get a pack and post the results.
Old Mar 7, 2008 | 10:39 PM
urielaudi's Avatar
also go and check the connection on the coil pack maybe that bump massed up something but it should be well intact
Old Mar 7, 2008 | 10:42 PM
urielaudi's Avatar
well i would switch that coil pack, with another cylender if the connections are ok their, all compatible. and use check engine light scanner and it wont say cycle 2 it shell say the one were you replaced cycle 2
Old Mar 7, 2008 | 10:43 PM
Yea that was the first thing I checked but it wasn't it[>:]
Old Mar 7, 2008 | 10:45 PM
urielaudi's Avatar
lol switch the coil pack cylender 2 with another and see what happens you know what i mean ? that way tommerow u know that for sure your gonna spend the money on the right part ,also what kind of audi is it?
Old Mar 8, 2008 | 11:38 AM
Ok so I replaced the coil pack with a new one and same thing. What do I do now? I was told it could be an injector or a few other things.
Old Mar 8, 2008 | 11:53 AM
  #18
techbod's Avatar
im in hospital 7 days a week[:-]
Old Mar 8, 2008 | 02:55 PM
  #19
Ok, I did the coil and plugs and its still same thing? what do I do next?
Old Mar 8, 2008 | 06:27 PM
  #20
auditech79's Avatar
Coils on PRE 2000 1.8Tcars almost "NEVER" go bad. The problem is gonna be your ICM (ignition control module) on top of the airbox. You can get a new one at www.ecstuning.com Its very common to get a cylinder 2 missfire when one of these go bad also.
