f-125 aftermath woes
Old Feb 5, 2013 | 06:48 PM
goldi's Avatar
Default f-125 aftermath woes
I have a a 1997 a4 quattro with auto trans and my problems initially started with the multi function switch losing reverse and occasionally would say D is 4 and 3 and park became 2nd. After replacing the switch i Icould shift to the correct gears but got multiple trans codes in this order
00652 - Gear Monitoring: Implausible Signal
00297 - Gearbox Speed Sensor (G38): No Signal
17125 -Torque Converter Clutch: Stuck OFF / No Power being transferred
I recently replaced my mfs switch thinking all would be well after getting back reverse.
I got each code one after the next over the past couple days in that order. once its moving if i clear the codes it returns to almost normal dropping rpms to what seems normal. Any ideas or past experience guys?
crazyone
Jun 13, 2011 10:26 PM
busa jocky
Apr 2, 2010 07:53 PM
theTTkid
Jul 22, 2008 11:04 AM
audiRSallroad
Apr 5, 2008 12:22 AM
