Factory bov noise?
I have a 2000 a4 1.8t quattro n I hear a small air release wen I get on it from 1st to 2nd n its an automatic. It's all stock. My dv go bad?
You may be hearing the DV dumping surge air back into the system. If you're not seeing a CEL and the car pulls nicely after you get off it and jump back on, then your DV is working right.
What's CEL?
CEL = check engine light
the diverter valve should only come into play when you let off the accelerator.
yeah i hear that too anytime i shift gears around 0-5 psi, mine has a check engine light on, problem was system to lean or something like that idk, car runs just fine, sounds like a butterfly bov.... is there a way to make it louder? :D
Originally Posted by poopsman
(Post 1323897)
Replace the diverter valve and the vacuum line to the DV. When you go to the dealer, ask for the TT 225 version of the DV, it's a lot cheaper than the "stock." Replacing the DV with a BOV or leaving it open will cause rich dumps between shifts, causing the check engine light to come on eventually. |
