Factory bov noise?
yeah i hear that too anytime i shift gears around 0-5 psi, mine has a check engine light on, problem was system to lean or something like that idk, car runs just fine, sounds like a butterfly bov.... is there a way to make it louder?
Replace the diverter valve and the vacuum line to the DV. When you go to the dealer, ask for the TT 225 version of the DV, it's a lot cheaper than the "stock." Replacing the DV with a BOV or leaving it open will cause rich dumps between shifts, causing the check engine light to come on eventually.
ZIV3R
09-20-2007 02:02 PM
