Fault code P1128 Long Term Fuel Trim Bank1 System too Lean
Old 07-04-2008, 03:52 PM
CRAZYHAWK's Avatar
Default RE: Fault code P1128 gone, but now P0102
As Mike@DTH said, make sure the MAF is plugged in. Also check
all vacuum lines for leaks.
Old 09-24-2009, 11:19 AM
kbrookst's Avatar
Default Similar problem..
I have two codes p0102 and p1128...i checked for vac leaks, cleaned the maf and confirmed its working....
the light LITERALLY came on 20 seconds after i put fuel system cleaner in the tank. Anyone know if this stuff could have caused the codes???
Old 09-24-2009, 05:40 PM
CRAZYHAWK's Avatar
Clear the codes and see if they return.
mandito219
02-07-2010 07:03 PM
antonio
12-13-2009 02:20 PM
smahar
08-07-2009 10:58 AM
RCFerrari
02-04-2007 12:28 AM
vendingman2000
02-03-2007 05:10 PM
Quick Reply: Fault code P1128 Long Term Fuel Trim Bank1 System too Lean
