FMIC boost sensor
Old Mar 24, 2008 | 10:28 AM
compmanben's Avatar
Default FMIC boost sensor
OK I started my FMIC install yesterday (for those of you that saw my SMIC + FMIC thread). Here are some pictures of the install. My question is, after looking through about 8 different guides on FMIC installs, the only guides that even mentioned the boost sensor from the stock intercooler were the premake kits from companies which have a hole in the pipe to accomodate. What do people with the eBay kit do about the boost sensor? Also, for the passenger side - do most people just run to the stock rubber pipe that goes up to the turbo? Thanks for the help.
[IMG]local://upfiles/47894/E75E12DA94F8415B8DE22218E7303019.jpg[/IMG]
[IMG]local://upfiles/47894/36C4CA0509524FD48A3383B1F5FBDBBF.jpg[/IMG]
[IMG]local://upfiles/47894/105972C47C704558BEC17EB70F32ABB7.jpg[/IMG]
Old Mar 24, 2008 | 10:49 AM
turbo kraut's Avatar
Tech Guru
Default RE: FMIC boost sensor
the "thrust sensor" needs to be attached..... liefer, i think it was.... used jb weld..... i had a bung made/being made for mine, will show pix, when the car is back
as for the other.... my sap is being relocated... again liefer, i think..... took his sap out and ran through that hole.......https://www.audiforums.com/m_810844/tm.htm
Old Mar 24, 2008 | 10:51 AM
EliteTuning1's Avatar
yeah i just drilled a hole for mine and jb welded it in there. works fine. i also used the stock tube from the turbo yes.
Old Mar 24, 2008 | 11:18 AM
compmanben's Avatar
what's a sap?
Old Mar 24, 2008 | 11:23 AM
hiwords's Avatar
secondary air pump, it's the black thing on the passenger side of your car
Old Mar 24, 2008 | 11:27 AM
compmanben's Avatar
OH ok, yeah that's the pump that I ran the tiny filter to when I put on my evoms. Cool I'll try to do this:
Just drill a hole in it and get a tap/dye set to make the threads to hold the sensor in. (onepoint8tee)
Old Mar 24, 2008 | 03:29 PM
Leifer's Avatar
The thing on the drivers side = MAP sensor. You need a map sensor flange. Then you drill a hole in the piping and weld it on. If you have steel piping, get a steel flange, and alum to alum, that way you don't have to ghetto-JB weld it.
The thing on the passenger side = SAI/SAP. Secondary air injection/intake/pump, whatever you wanna call it. You can delete it, but the n112 valve needs to have a resistor placed in it to fool your ECU so you don't get a CEL from having it removed from your car.
Old Mar 24, 2008 | 03:34 PM
pimphell's Avatar
Here's a link to a map bung.....
http://store.42draftdesigns.com/18T-...it_p_6-43.html
Old Mar 24, 2008 | 03:37 PM
pimphell's Avatar
ORIGINAL: Leifer
I hope to have an awnser to the resistor that needs to be on the n112 valve, unless someone has already done that?
Old Mar 24, 2008 | 03:39 PM
pimphell's Avatar
by the way, what is the measurements of your fmic?
