fog light help...
Old Sep 12, 2011 | 02:07 PM
raudi28's Avatar
Cool fog light help...
2000 a4 facelift. recently my right fog light has been working intermittently, IE working every once in a while, i thought the bulb was blown the first time it went out so i didnt think much but then i noticed there was a residue on the housing, thought maybe a bad seal and moisture got in. sooo today i took out the housing and opened it up to find a white residue all over the inside of the housing. the prongs on the bulb looked a little burned, i am wondering what could have caused this? could i have put the plug on backward when i replaced the bulbs with yellow a few months ago? should i stop using my fog lights until i figure out what caused this? ANY information will help. Thanks!
Old Sep 12, 2011 | 04:56 PM
airguard350's Avatar
Tech Guru
I would probably stop using them. Moisture + electricity= bad times.
Old Sep 12, 2011 | 10:14 PM
raudi28's Avatar
No there was no moisture in the housing. All seals looked good and there was just the white residue that i thought might be moisture when i first saw it. It almost looked like the bulb shorted out but it still works. I took apart the housing, put it back in and now it works all the time. I just want to know what could have caused that and if i have a problem
Old Sep 12, 2011 | 11:30 PM
TaConklin's Avatar
Sounds like it might have been some kind of corrosion from a bad connection.
Old Sep 13, 2011 | 01:08 AM
raudi28's Avatar
I guess its not as simple as i thought... but if i had put the plug on the bulb backward could that do it? Or can it go both ways? The prongs are the same size
Old Sep 13, 2011 | 01:13 AM
MetalMan's Avatar
Incandescent bulbs such as the typical halogen bulbs used in fog lights have no polarity. So they can be plugged in either way.
Old Sep 13, 2011 | 10:07 AM
raudi28's Avatar
Well this is a mystery to me. They have worked since i took the housing apart. Must have been a bad connection or something
Old Sep 26, 2011 | 04:20 PM
raudi28's Avatar
finally figured this one out.... when my right fog light started working again and the left one stopped, i decided to check out the bulbs. of course the yellow bulbs i bought were 100 watts, the old ones were 55 watts. on a positive note i thought i fried the housing but i put the old bulbs back in and they are still working wheww
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
