Which Forge?
Hey guys,
Looking to upgrade my stock DV, and was wondering what the difference/pros and cons to the Forge Splitter and Forge 008 DV. Any advice or suggestions would be greatly appreciated! =) |
The main advantage of metal piston-style DV's like both of the examples you posted is that they're rebuildable. They also (typically) come with a coupla different springs so you can use them effectively with different boost levels. Of the two you posted, the splitter will be a little bit louder, but beyond that its up to you. If you're going to keep the car mostly stock, a 710n DV from the 225hp TT would do just fine, that's what I'm running. If you're going to be running higher boost though, you may as well invest in a better DV now and just change the spring out later.
Ah, ok! Do you happen to how much boost the 710n can handle?
Originally Posted by Brochacho
(Post 1378224)
Sorry, missed that last post I guess. The 710n is fine for upwards of 15psi. Any more than that and I would upgrade to a piston style DV with a stiffer spring.
Originally Posted by CCA4
(Post 1408635)
| All times are GMT -4. The time now is 02:18 AM. |
