Which Forge?
Old Apr 15, 2012 | 10:38 PM
Brochacho's Avatar
Default Which Forge?
Hey guys,
Looking to upgrade my stock DV, and was wondering what the difference/pros and cons to the Forge Splitter and Forge 008 DV. Any advice or suggestions would be greatly appreciated! =)
Old Apr 16, 2012 | 10:21 AM
CCA4's Avatar
The main advantage of metal piston-style DV's like both of the examples you posted is that they're rebuildable. They also (typically) come with a coupla different springs so you can use them effectively with different boost levels. Of the two you posted, the splitter will be a little bit louder, but beyond that its up to you. If you're going to keep the car mostly stock, a 710n DV from the 225hp TT would do just fine, that's what I'm running. If you're going to be running higher boost though, you may as well invest in a better DV now and just change the spring out later.
Old Apr 16, 2012 | 04:59 PM
Brochacho's Avatar
Ah, ok! Do you happen to how much boost the 710n can handle?
Old Oct 20, 2012 | 08:40 PM
mrb5_supra_wrx's Avatar
Yeah what this guy said I don't see why this question was never answered..
Old Oct 21, 2012 | 07:53 AM
CCA4's Avatar
Sorry, missed that last post I guess. The 710n is fine for upwards of 15psi. Any more than that and I would upgrade to a piston style DV with a stiffer spring.
Old Oct 21, 2012 | 12:55 PM
Emilgevor's Avatar
Some stage 3 S4 guys swear by 710N but i guess they have boost tuned down a bit. I personally have APR stg1 and its around 19-20 spike and 17.5 holding strong. DV was the first thing I upgraded on the car. I went with forge replica one because I did not want to spend $180 on one when I got one for much cheaper. Point is that with after market DV i can switch springs and adjust to my needs very easily. Also I would suggest looking into Adjustable DV that adjusts with a simple turn of the head on the DV.
NuYorka103185
May 18, 2011 01:13 PM
vegastt
Sep 4, 2007 12:18 AM
blaznD
Jul 1, 2007 02:26 PM
.clipse
May 15, 2007 11:55 AM
dtmguy
Apr 16, 2007 03:24 PM
