Front Axle bolt NOT TTY in kit ???
Old Mar 23, 2016 | 09:53 PM
TheCounty's Avatar
Default Front Axle bolt NOT TTY in kit ???
Replacing front right half-shaft for 2001 A4 Quattro.
Replacement shaft in box from "Cardone". Bolt that came with axle
was a conventional looking "hex head" instead of
usual 17mm socket head. Length the same & thread size.
Instructions with kit were vague and stated "approx" 170 ft-lbs
for such FWD axles. Called tech support for Cardone & they
didn't seem to know squat! Had to describe what a TTY bolt was.
Did not use this bolt as I keep VW/AUDI spares at hand & used one of
those.
Any thoughts or similar experiences??
Cheers
TheCounty
Old Mar 24, 2016 | 02:19 PM
redline380's Avatar
Legal Moderator
First off, Cardon isn't the best for axles. But since you already have it in...
Not sure why the new bolt had that type of head. I always reuse mine though. And FYI, the torque spec is ridiculous, something like 180 degrees after 170 lb ft. It is a lot.
Sportscar
Jun 25, 2014 10:34 PM
achTTung
Jun 2, 2008 10:33 PM
bdmstang
May 22, 2007 06:23 PM
