Fuel Filter
Old Mar 18, 2010 | 05:10 PM
MrEvans86's Avatar
Member
Talking Fuel Filter
I just bought my car 3 weeks ago so I'm just starting the typical maintenance and next up is the fuel filter, so is there access to the filter and tank under the rear seat or do you have to get at it under the car? Also is there a schrader valve on the fuel rail, or do you have to pull the fuse to release the fuel pressure? thanks
Old Mar 19, 2010 | 04:56 AM
joenelson7687's Avatar
Fuel Filter Replacement DIY:
http://www.audiworld.com/tech/eng49.shtml
Old Mar 19, 2010 | 07:20 AM
MrNotSoTechnical's Avatar
Be careful removing the banjo bolt. I tried twisting it too hard ( it was beyond rusted, and I had been using PB blaster for several days), ended up snapping the lower fuel line and had to get it patched..
Old Mar 19, 2010 | 07:47 AM
scorpionking0102's Avatar
The fuel filter is fairly easy to replace if you take into consideration some of the formentioned tips from other owners. It's just in front of the ight rear wheel housing near the frame rail. But, remember to replace the "copper slugs",i.e. washers, on both sides of the banjo fittings. They take a a pattern set and could possibly leak. Besides it's good a idea, it's cheap, and a common practice of good mechanics.
Old Mar 24, 2010 | 07:33 PM
Default Fuel filter replacement
You shouldn't have to pull a fuse. "Just be careful" when you loosen the banjo bolts have a drain pan handy to catch the pressurized fuel in the lines, it should eventually bleed off assuming the key is not on. Also, for safety sake, wear safety glasses and don't use a drop light to illuminate the work area. Can you say "Fire"? Try to do it during the day when you can have plenty of natural light. If you jack it up to gain more working room under the car make sure you have jack stands under the hard mount points so the car doesn't fall on you and make sure you're on a level surface. Audi's are heavy cars. Nuff said.
Old Mar 25, 2010 | 10:56 AM
i couldn't resist
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
DJmart
Aug 3, 2013 11:08 AM
ironman
Apr 16, 2007 03:53 PM
