Fuel level sensor
Ok..so i replaced my fuel pump last month and now my fuel level will only register at about 7/8 of a tank when the tank is full...When i was replacing the fuel pump there is no way to get it out of the tank without banging into the fuel level sensor about 20 times..so my question is does anyone know how to ajust the sensor so that it givea me an accurate reading...
Can you go further on empty than before? if so the arm of the sender attached to the float got bent upwards somehow, so that with the tank full and the float all the way against the top of the tank, the other end of the arm attached to the resistor network can no longer reach full scale.
Just bend the float lever (the actual float arm at the float) so the float will be lower in the tank when installed. Shouldn't take much maybe 1/4" or so.
Heres some pictures of what the senders look like.
http://www.audizine.com/forum/showth...l-sending-unit
