Garrett Turbo Gauge Installation
Old Mar 16, 2008 | 09:01 PM
CIA's Avatar
CIA
Default Garrett Turbo Gauge Installation
This weekend i found some spare time and i wanted to install the turbo gauge on the car. Thing is that i dont want to have a straight gauge in the central vent. I want to have the gauge directed on the driver side. So i did like everybody else buy cutting the vent but i did this with about 15-20 degree angle.
It was not the easy part. I spent 3 hours with the dremel to get at this shitty result.As you can see there its far from perfect. But i
got the angle i wanted.
Next step was to figure out a way to hide all those imperfections/spaces between the gauge and the vent. My solution was to use
some kind of glue. I say glue but its not. Its a high $$$ putty that my father uses to assemble plane/helicopter parts. It takes about 24h before the putty gets hard like a metal.
Now we all agree that now it looks like ***. So i had to wait about 1 hour before i could take off the excess of glue out of the vent.
Trick is: water and soap. So with a lot of patience i took the excess of glue off. Took me 1h to do it.
Now it looks like that. Thiswas the last step before 24h wait/painting.
Tomorrow i will refinish the vent with a paint job.
Old Mar 16, 2008 | 09:14 PM
blueboost99's Avatar
Default RE: Garrett Turbo Gauge Installation
looks good man i like how you have it angled in. i justdid acenter vent auto meter boost gauge
Old Mar 16, 2008 | 09:20 PM
Jeff's Avatar
Zombie Defense Force
i like the angle that you have. im surprised more poeple dontt do that
Old Mar 16, 2008 | 09:24 PM
cincyTT's Avatar
I'm make believe
Because i can take a hole cutter and make a far cleaner job
Old Mar 16, 2008 | 09:54 PM
CIA's Avatar
CIA
its a good idea cincy if you have the good diameter hole cutter, if not..
Even there i had to cut on the back of the vent to obtain this angle.
Old Mar 16, 2008 | 10:04 PM
The Bishop's Avatar
ORIGINAL: Jeff
I did it. although mine isn't as much of an angle.
Old Mar 16, 2008 | 10:11 PM
cincyTT's Avatar
I'm make believe
You steal a TT vent cover?
Old Mar 16, 2008 | 10:24 PM
The Bishop's Avatar
Me? no. that's a piece of pvc pipe filled with bondo and has a hole cut out of it. You know I'm wierd like that.
Old Mar 16, 2008 | 10:35 PM
1.8TK3MP's Avatar
garrett gauge my a$$...looks DEAD on a prosport gauge
FYI i have prosport gauges
Old Mar 16, 2008 | 10:38 PM
CIA's Avatar
CIA
