gas gauge is not working...
Old May 24, 2009 | 10:03 PM
gedas429's Avatar
Default gas gauge is not working...
hi everyone i have a little problem. my gas gauge is not working normally, sometimes it show that i have full fuel tank some times its showing that i have empty even i have filled up my tank fully. if anyone can help please do! thanks!
Old May 24, 2009 | 11:38 PM
crystaladam08's Avatar
wierd........mine always goes to empty and it always takes about 10 gallons to fill up. I know there is 6 more gallons in there, just don't know why it does it.
Old May 25, 2009 | 12:02 AM
gedas429's Avatar
yea i know... because i filled up my tank today all the way and it just show sometimes that i have half tank left sometimes i'm on empty and sometimes i guess it show the full tank which i suppose to have
Old May 25, 2009 | 10:28 AM
hiwords's Avatar
it's know as the erratic gas gauge. there's a level monitoring unit in the gas tank that monitors the level. if you lift off the carpet in the trunk, there's large circular cover with 3 screws on it that you can take off. once that is off you'll see the cover for the gas tank. undo the electrical harnesses and the 2 fuel lines. then take off the black ring looking thing but unscrewing it. you need a special tool to remove it but 2 screw drivers at opposite sides of it work too. once that is off you can lift the top off. if you reach your hand in the gas tank, there's only one thing stick out from the bottom. the whole thing is basically smooth until you get to the bottom there will be a bulge, it's just a clip so just push on the bulge and pull up. once you get the unit out, you'll see that it's works like a toilet, there's a thing that floats and then there's 3 wires i believe that senses the gas level. one of them is probably loose. also clean the the contact where the floating thing touches the metal on contact on the unit. pm me if you have any other questions. i hope you can do the job yourself and make sure you're low on gas before you do it unless you like gas all the way up your forearm.
Old May 25, 2009 | 10:49 AM
jiggleo's Avatar
to add to hiwords' advice, the fuel sending unit works on variable continuity so make sure the connection to ground is good. you can check the unit itself by reading checking continuity to ground as you slide the float up and down. That would let you know if it's a bad connection or the sending unit itself.
Old May 25, 2009 | 09:08 PM
gedas429's Avatar
thanks hiwords and jiggleo!! i'll try to do that
Old May 26, 2009 | 11:12 AM
captschippy's Avatar
After driving Heartland Park Track last weekend, My guage worked fine until I left the track to go home. Guage went to empty,empty symbol came on, even though there was still half tank. Filling up did not correct. Is it possible to jam the float due to high speed track driving? Also, is the sending unit and pump on the 2001 A-6 one unit,or seperate? Thanks.
Old May 26, 2009 | 04:07 PM
hiwords's Avatar
knowing audi it's probably the same configuration. there's no way the float could get stuck though
Schten
Jan 25, 2014 01:42 PM
audi4a
Nov 19, 2007 09:07 PM
mfcineurope
Jun 26, 2007 04:57 PM
obsolete
May 7, 2007 12:29 AM
dw03
Jul 17, 2006 12:52 AM
