gear ratio question. .
Old Dec 2, 2012 | 06:36 AM
Subarashī Kao's Avatar
Default gear ratio question. .
so ill get to the point quick, is it just me or does the audi a4 1.8t have some short *** 1st and 2nd gear?
when i try to floor it i hit redline (6300rpm)like stupid fast then i gotta jump to 2nd and that 2 goes by stupid fast until 3rd it holds it a little long. i have that pc16+injectors file i know it makes ok torque but dam i cant even hold 1st gear for 2 sec bc am already passing redline same with second gear.
is this normal? or is there something else am missing here?
Old Dec 2, 2012 | 07:38 AM
jonbonesjones's Avatar
Moderator
Economy trans, its a little shorter. The 2.8 trans swap is dont by some to fix the problem you speak of. Its a direct bolt on.
Old Dec 3, 2012 | 01:59 AM
i see i always thought short gears killed more gas than long but anyways thats intresting i might go to the junk yard then i remember seen 4 2.8L there problem is finding one that is quattro bc i do need the awd if i have awd correct?
also i was thinking of working on the head and internals you know springs so i can rev higher, rods, crank etc i am going big turbo so i was thinking this might be a better idea . what do you think? or should i go look for the tranny?
Old Dec 3, 2012 | 02:46 AM
meh.'s Avatar
It isn't really worth it. There aren't much difference between the 2.8 and 1.8 transmission. There was a thread about it on AZ a few weeks ago.
Old Dec 3, 2012 | 04:10 AM
o really? so then i should just high rev build the head and take it from there then? seems like the better option. it the statement about the 2 tranny's been close to the same thing then there is no reason to change it.
Old Dec 3, 2012 | 08:16 AM
Moderator
The 2.8 is taller through each gear, not by much tho. They both have the same final drive
1.8
3.778:1
2.176:1
1.429:1
1.029:1
0.838:1
2.8
3.500:1
1.944:1
1.300:1
0.943:1
0.789:1
Old Dec 3, 2012 | 07:10 PM
meh.'s Avatar
Or just get accustomed to driving it.
Why would you build a "high rev head" if the K04 will likely run out of breath by then?
Old Dec 4, 2012 | 08:52 AM
Moderator
Because after said head is built. Turbo possibilities are now practically unlimited.
Old Dec 4, 2012 | 02:53 PM
meh.'s Avatar
Oh, I didn't see that he was planning on getting a bigger turbocharger.
If you plan on going bigger, I would get rods before getting the head built.
Old Dec 5, 2012 | 03:34 AM
well i am planing on doing it all in one blow head build(springs,retainers,exhaust valves) and rods all at the same time i might even get forge crank while am in there why not but thats a maybe i still think the stock crank can handle good was looking into maybe a better intake manifold i seen some good looking ones and i think the BT set up well benefit better from it than a small turbo. am still making the list, right now i just order exhaust/catback and the test pipe came up to $450 total for that i need the exhaust anyways and the test pipe so that was a must get now.
