Giac chip then a few problems
Old May 5, 2010 | 04:50 PM
Baby Kito's Avatar
Default Giac chip then a few problems
Got my giac last week. Def felt power. But now my engine light is on and not as much power? Maybe running to lean or rich. Boost leak. Idk. Hoping someone could help
Old May 5, 2010 | 04:53 PM
McGovs2.7TB5's Avatar
Its hard to guess over the internet. Get your codes pulled and then come back
Old May 5, 2010 | 07:57 PM
airguard350's Avatar
Tech Guru
^ x2. Auto Zone will do it for free and so will Pep Boys, but only if you have their rewards card.
Old May 6, 2010 | 08:13 PM
Baby Kito's Avatar
guy said the code was p113. since i need 4 digits im guessing it was p1130. said it was a dealer code and thats all i got. soooo.....
Old May 6, 2010 | 08:34 PM
exequiel3k's Avatar
P1130
Long Term Fuel Trim mult.,Bank2 System too Lean
Hope this helps!!
Old May 6, 2010 | 09:43 PM
jjcrt2's Avatar
im telln ya man change ur plugs. run ngk bkr7e gaped at .028 they are a colder heat rateing so this might help you clean up your lean problem. do u have a boost gauge yet can you notice a drastic loss in power. now you deffently need to replace all of your vacuum lines.
Old May 6, 2010 | 09:47 PM
turbo kraut's Avatar
Tech Guru
you are more than likely in limp due to the lean code... get plugs, get a guage and come see us in the morning
Old May 6, 2010 | 10:05 PM
Baby Kito's Avatar
Do I honestly need a gauge? Im getting the plugs tomorrow and hopefully getting all the vaccum lines checked. I don't think Im in limp cause It's like Im back to my original power before the chip kinda. Im getting a new Turbo inlet pipe later this weak as well, thought that might also be a good idea
P.s._What size vaccum hoses do I need. Ill order some silicone ones as soon as I have the size
Old May 6, 2010 | 10:19 PM
jjcrt2's Avatar
with a turbo car a boost gauge is your best friend to tell you exactly whats going on itll help out alot its a good investment pretty much
Old May 6, 2010 | 10:34 PM
Baby Kito's Avatar
Well Ill prob get one in the future but for now Id rather spend the money on the parts before I get it. if you think I should replace all my lines then what size tubing should I get. I can order tonight and maybe have them by saturday or friday
