Got a giac, and a question
Old Aug 14, 2008 | 11:38 PM
Jc61990's Avatar
Default Got a giac, and a question
Ok so i bought a chip, i got it on ebay for really cheap so if its the wrong one, i can probly resell it and get my money back, but anyway.... the chip i got says on it "CLGL02 V20"
will this work with my car?
Old Aug 14, 2008 | 11:50 PM
Jc61990's Avatar
oh, also the guy said its for AEB engines, and i have an AEB,
Old Aug 15, 2008 | 12:02 AM
onepoint8tee's Avatar
If it's for an AEB engine, it should work. There might be a problem if you have tip and it's out of a manual though.
That # probably won't mean anything to anyone around here. Use the dealer locator link at giacusa.com see if they know anything. If it will work, your ecu will need socketed. That means youll either have to drive to or send your ecu to a giac dealer to have it soldered in.
Old Aug 15, 2008 | 12:06 AM
Jc61990's Avatar
do you think it could be done at home, my dad works on computers for a living, and has soldered much smaller chips than this before. or you think i should still send it out, i have a USB-Vagcom and all the software so i can set it up. and if i do need to drive to one, how much do you think it would be to get it installed, the closest dealer is like 45min to an hour away from me
Old Aug 15, 2008 | 12:10 AM
Audi_Skydiver's Avatar
http://www.youtube.com/watch?v=bjayVSCiF14
Watch that video... There is a video of the soldering job that they did on my A4 when I had it. It's about half way through the video.
Josh
Old Aug 15, 2008 | 12:20 AM
Probably worth the drive, and the $100 or so that they'll charge. You need more than just that chip. You need a socket solderded to your ECU that the chip sits in. I wouldn't consider it a DIY kinda thing.
Old Aug 15, 2008 | 12:24 AM
Me either... I would rather spend $100 to have it done right then 600 to buy a new ECU if you fry yours.
Josh
Old Aug 15, 2008 | 12:26 AM
Jc61990's Avatar
ah, it looked like a chip that sits in a socket. ok, looks like im driving to jamica on my day off soon
Old Aug 15, 2008 | 12:31 AM
Even if the chip ends up being compatible w/your ecu, don't quote me on that $100 for installation/labor. It could end up being more or less than that.
Old Aug 15, 2008 | 12:37 AM
Jc61990's Avatar
ok, then ill probly go with like 200$ just to be safe, hopefully it doesnt cost more than 200$
