Got my Audi Secret Santa gift today!
Another DOH moment. I looked over my remaining parts and realized there was a new push down part included for the spring. this is what alex was talking about. X\ lol got it in, resounding CLICK and its super solid! =D no dremel required!
So to say that the new rail bushings made the shifter feel more solid is a bit subjective, but they definitely keep the shifter from moving around as much as it did with the original rubber bushings.
Soon you're likely to start noticing the play that the stabilizing linkage (the one that adjusts the forward/backward positioning of the shifter) introduces to the shifting setup. With the boot off you'll see the shifter move forward/backward when going between gears, and this motion is compounded by the reduction in throw. I've been contemplating this:
http://jhmotorsports.com/shop/catalo...7f2faaf87ee81f
If I get really ambitious and want to rid the shifter of most of the play then I'd replace the shifter linkage attachment piece:
As for the push-down reverse pin, I installed mine straight. My ebay shifter came with instructions (did yours?) that said to install it straight. At first it was difficult to engage reverse because of the orientation of that pin. Over time the pin has put itself at a bit of an angle relative to the rod, and shifting into reverse became much easier.
It is done! And i am happy with it, but it will probably need adjustments. I'm too tired to do this tonight though, so I'm going to go to bed. It shifts fine, and its stiff. The shifter wiggles side to side same as stock though but whatever. The shifts are so short! It feels sporty, which is something the old Audi hasn't felt like in a long while.
I'm going to bed. Tomorrow i'll trim the boot spacer to fit. Thanks for all the help AF.
I ended up removing the entire spacer and plastic ring at the top to get it to fit my SS and ****.
I got sooo angry at the stupid bolts. It took so much time to get everything in. I did end up losing one of the 10 mm Flange nuts that hold the shift bucket up to the body, but I just bought one at ACE, no worries. Also bought a magnet which was invaluable.
Last time I reinstalled my shifter I think I only dropped it once!
