GTRS problems still please help me out!
Old Feb 21, 2008 | 12:38 AM
gotaudi's Avatar
Default GTRS problems still please help me out!
ok I have had these problems since installing the turbo about a year ago.
The problems are I pull an extreme amount of timing. I am pulling about 8 degrees at 15 psi.
Also the fuel trims still say +22.5% at part throttle. Today i reset the fuel trims and didnt go into boost for a few miles. The fuel trims went back up to the +22.5% out of boost shifting at about 3000rpms for about 20 miles. the value doesnt change when in boost.
I changed the MAF sensor again and no change. I switched my FMIC about a month ago and it didnt help with the timing problems like I anticipated.
can any one of you shed some light on me?
Here are 3 logs I did today all are in 3rd gear at 1.07kg/cm^2 or about 15psi (This is running straight from the wastegate)
http://spreadsheets.google.com/pub?k...lVVsTJkTIFWEUQ
Old Feb 21, 2008 | 12:45 AM
cincyTT's Avatar
I'm make believe
Default RE: GTRS problems still please help me out!
Is this still the same tune from a year ago? If it is, go back and have it updated.
Old Feb 21, 2008 | 12:46 AM
gotaudi's Avatar
it is the most recent tune from unitronics
Old Feb 21, 2008 | 12:54 AM
cincyTT's Avatar
I'm make believe
which cc file? what injectors?
Old Feb 21, 2008 | 12:57 AM
gotaudi's Avatar
I am running the 440cc file at 4 bar. The injectors are the Bosch greengiants rated at 440cc @ 3 bar. They are the injectors form the Volvo R.
Old Feb 21, 2008 | 01:11 AM
cincyTT's Avatar
I'm make believe
You might need to throw in a 3bar in there and/or ditch the sh!tty greentops [:'(]
The spray pattern is not a good match for the 5v head
Old Feb 21, 2008 | 01:18 AM
gotaudi's Avatar
I dont have the greentops (I use to and they sucked) I have the greengiants they have the same spray pattern as stock injectors, I have a great idle
Old Feb 21, 2008 | 01:23 AM
cincyTT's Avatar
I'm make believe
find a local with a gti/jetta/TT with a 1.8t and steal there 3bar and see if that helps. If that doesnt work, im stumped.
Old Feb 21, 2008 | 01:25 AM
gotaudi's Avatar
wouldnt the 4 bar provide more fuel? I have a 3 bar sitting around, This is what I originally put in but unitronics told me the file is written for a 4bar FPR.
Old Feb 21, 2008 | 01:29 AM
gotaudi's Avatar
Also what about the timing pull what do you think that could be related to?
